CE10 fault delta ms300 drive
Cause : Modbus transmission time-out comes when incorrect communication command from upper unit or malfunction caused by interference.
The CE10 fault in MS300 drive indicates an Modbus transmission time-out. This means the communication time exceeds the detection time for communication time-out.
  1. Check if the communication command is correct.
  2. Check if the setting for Pr.09-02 is the same as the setting for the upper unit.
  3. Check the cable and replace it if necessary.
