Delta Servo Drive
273
Nov 16, 2024 10:16 am
AL077 alarm in delta servo drive indicates Encoder computing error. This means there is an internal error of motor encoder.
- Check if the motor is well grounded.Â
- Check if the encoder cable is separated from the power supply or any high-current cable to avoid interference.
- Check if the encoder uses shielded cable.
- Check the motor speed.
