oL fault in delta VFD-L series drive
How can resolve problem oL fault in delta VFD-L series drive ?
Topic Tags
The AC drive detects excessive drive output current
1. Check whether the motor is overloaded.
2. Reduce torque compensation setting as
set in Pr.7-02.
3. Increase the AC drive’s output capacity.
4. Note: The AC drive can withstand up to 150%
of the rated current for a maximum of 60
seconds.
Check wiring.
