WHY DO WE NEED FUSE AND HOW DOES IT WORK?
We need fuses in electrical circuits to provide protection against overcurrent conditions, such as short circuits and overloads, which can cause damage to equipment, electrical fires, and safety hazards. Fuses work by interrupting the flow of current when it exceeds a predetermined threshold, thereby preventing further damage to the circuit and connected devices.
Here's how fuses work:
  1. Fusing Element: A fuse consists of a fusing element, typically made of a metal or alloy with a low melting point, such as copper, silver, or tin. The fusing element is designed to melt or "blow" when subjected to excessive current flow.
  2. Enclosure: The fusing element is housed within a protective enclosure, usually made of glass, ceramic, or plastic, to contain any molten metal or debris produced when the fuse operates.
  3. Connection: Fuses are connected in series with the electrical circuit they are protecting. When current flows through the circuit, it also flows through the fuse.
  4. Overcurrent Condition: If the current in the circuit exceeds the rated current of the fuse, due to a short circuit, overload, or other fault, the fusing element heats up rapidly due to the Joule heating effect.
  5. Melting of Fusing Element: As the fusing element heats up, it reaches its melting point and melts, or "blows," interrupting the flow of current through the circuit.
  6. Open Circuit: Once the fusing element melts, the circuit is opened, and current flow is interrupted. This prevents further flow of excessive current through the circuit, protecting connected devices and preventing damage or hazards.
Fuses are available in various types and sizes, each designed for specific voltage and current ratings and different response characteristics. For example, fast-acting fuses respond quickly to overcurrent conditions and are suitable for protecting sensitive electronic devices. In contrast, time-delay fuses have a slower response time and are used to protect circuits with inductive loads or transient current surges.
In summary, fuses are essential components of electrical circuits that provide protection against overcurrent conditions by interrupting the flow of current when it exceeds safe levels. They operate by melting a fusing element when subjected to excessive current flow, thereby preventing damage to equipment and ensuring the safety of electrical installations.
