difference between dol and star delta starter
DOL (Direct On Line) starter and Star-Delta starter are two common methods used to start induction motors.
Direct On Line (DOL) Starter
  • Principle: The motor is directly connected to the power supply from the start.
  • Starting Current: The starting current is typically 6-7 times the full-load current, causing a significant voltage dip and potential mechanical stress on the motor and connected equipment.
  • Applications: Suitable for applications with low to moderate starting torque requirements and where voltage dips are acceptable.
Star-Delta Starter
  • Principle: The motor is initially connected in a star configuration, reducing the starting current to about 1/3 of the DOL starting current. After a short time, the motor is switched to a delta configuration, increasing the voltage and torque.
  • Starting Current: The starting current is significantly lower than DOL, reducing the impact on the power supply and mechanical stress on the motor.
  • Applications: Ideal for applications with high starting torque requirements or where voltage dips are a concern.
Key Differences:
Feature DOL Starter Star-Delta Starter
Starting Current High Low
Voltage Dip Significant Minimal
Mechanical Stress High Low
Applications Low to moderate torque High torque
In summary, DOL starters are simpler and less expensive but can cause significant voltage dips and mechanical stress, especially for large motors. Star-Delta starters, on the other hand, offer a more controlled start and are suitable for applications with high starting torque requirements. The choice between DOL and Star-Delta starters depends on the specific needs of the application and the desired trade-offs between starting current, voltage dip, and cost.
