force guided relay vs normal relay
Both force-guided relays and normal relays (also known as general-purpose relays) are electromechanical devices used for switching circuits on and off. However, they differ in their internal construction and how they handle potential failures. Here's a breakdown of the key differences:
Normal Relay:
  • Construction: A typical normal relay has an electromagnet coil that attracts an armature when energized. The armature is connected to a set of contacts (typically Normally Open (NO) and Normally Closed (NC)) that switch positions when the coil is activated.
  • Operation: When the coil is energized, the armature is pulled in, causing the NO contacts to close and the NC contacts to open, allowing current to flow through the switched circuit. When the coil is de-energized, a spring returns the armature to its original position, reversing the contact states.
  • Failure Modes: A normal relay's main weakness is the possibility of contact welding. If high current flows through the contacts for extended periods, they can weld together, causing the relay to get stuck in either the ON or OFF state. Additionally, mechanical wear and tear on the moving parts can eventually lead to contact bounce (brief disconnection during switching) or complete failure.
Force-Guided Relay:
  • Construction: A force-guided relay incorporates a linkage mechanism that physically connects the NO and NC contacts. This ensures that when the coil is energized and the NO contact closes, the NC contact is mechanically forced open, and vice versa.
  • Operation: Similar to a normal relay, the coil activation switches the positions of the NO and NC contacts. However, the key difference is the forced mechanical linkage that guarantees both contacts cannot be in the same state (closed) simultaneously.
  • Failure Modes: Force-guided relays are less prone to contact welding because the linkage mechanism prevents them from sticking together. However, they are still susceptible to mechanical wear and tear over time. Another potential failure mode is breakage of the linkage itself, but this would typically result in a complete open circuit, which might be easier to detect compared to a stuck contact in a normal relay.
Applications:
  • Normal Relays: These are widely used in various applications due to their simplicity and cost-effectiveness. They are suitable for controlling low-power circuits and general-purpose switching tasks where occasional contact bounce or potential welding might not be critical.
  • Force-Guided Relays: These are preferred in safety circuits and critical applications where reliable switching and fail-safe operation are essential. They are often used in conjunction with safety light curtains, emergency stop buttons, and other safety interlocks because a single stuck contact wouldn't compromise the safety function.
Here's a table summarizing the key points:
Feature
Normal Relay
Force-Guided Relay
Construction
Electromagnet coil, armature, contacts
Electromagnet coil, armature, contacts, linkage mechanism
Operation
Contacts switch based on armature position
Contacts mechanically linked, ensuring opposite states (NO/NC)
Failure Modes
Prone to contact welding, mechanical wear
Less prone to welding, susceptible to wear and linkage breakage
Applications
General-purpose switching, low-power circuits
Safety circuits, critical applications requiring fail-safe operation
In conclusion, the choice between a normal relay and a force-guided relay depends on the specific application and desired level of reliability. For basic switching tasks, normal relays offer a cost-effective solution. However, for safety-critical applications where a single point of failure can have severe consequences, force-guided relays provide a more reliable and fail-safe option.
