How to measure flow rate of solid materials? - Gravimetric Feeder
Gravimetric feeders are commonly used to measure and control the flow rate of solid materials in various industrial processes. The measurement principle of gravimetric feeders relies on weighing the material as it is dispensed from a hopper or feeder into the process. Here's how the flow rate of solid materials is typically measured using a gravimetric feeder:
  1. Weighing System: Gravimetric feeders are equipped with a weighing system that accurately measures the weight of the material being dispensed. This weighing system typically consists of load cells or strain gauges integrated into the feeder mechanism or support structure.
  2. Material Dispensing: The solid material to be measured is stored in a hopper or reservoir located above the feeder mechanism. The material is dispensed from the hopper into the feeder mechanism through a controlled discharge mechanism, such as a screw feeder, belt feeder, vibratory feeder, or rotary valve.
  3. Weight Measurement: As the material is dispensed from the hopper into the feeder mechanism, the weighing system continuously measures the weight of the material. The weight measurement is typically performed at high frequency and with high accuracy to capture changes in the flow rate in real-time.
  4. Flow Rate Calculation: The flow rate of the solid material is calculated based on the change in weight over time. By dividing the change in weight by the time interval, the gravimetric feeder determines the mass flow rate of the material in units such as kilograms per hour or pounds per minute.
  5. Control System: Gravimetric feeders are often equipped with a control system that regulates the flow rate of the material based on setpoint values or process requirements. The control system adjusts the speed or operation of the feeder mechanism to maintain the desired flow rate.
  6. Calibration and Verification: Gravimetric feeders require calibration and verification to ensure accurate and reliable measurement of the flow rate. Calibration involves comparing the measured weight of the material with known reference values to determine the accuracy of the feeder. Verification involves periodic testing and adjustment of the feeder to maintain its performance over time.
  7. Application Considerations: When using gravimetric feeders to measure the flow rate of solid materials, factors such as material properties (e.g., density, particle size, flowability), feeder design, and process conditions (e.g., temperature, pressure, humidity) should be considered to ensure accurate and consistent measurement.
Overall, gravimetric feeders provide a reliable and accurate method for measuring the flow rate of solid materials in industrial processes. By continuously weighing the material as it is dispensed, gravimetric feeders offer precise control over the flow rate and ensure consistent material delivery for optimal process performance.
