Hydraulic Servo valves - basic types and operation
Hydraulic servo valves are precision control valves used in hydraulic systems to precisely regulate the flow or pressure of hydraulic fluid. They are commonly employed in high-performance applications where accurate and rapid control of hydraulic actuators is required, such as in aerospace, industrial machinery, robotics, and motion control systems. Hydraulic servo valves operate based on the principles of fluid dynamics and electromechanical actuation to provide precise control over hydraulic actuators.
There are two basic types of hydraulic servo valves:
  1. Proportional Servo Valves:
    • Proportional servo valves modulate the flow or pressure of hydraulic fluid in proportion to an electrical input signal.
    • They typically consist of a spool or poppet mechanism inside a valve body, actuated by a proportional solenoid or torque motor.
    • The electrical input signal (typically a voltage or current) controls the position of the spool or poppet, which in turn regulates the flow rate or pressure of the hydraulic fluid.
    • Proportional servo valves offer precise control over a wide range of flow rates or pressures, making them suitable for applications requiring fine adjustment and dynamic response.
  2. Servo Proportional Valves:
    • Servo proportional valves combine the functions of a servo valve and a proportional valve to provide both high flow capacity and precise control.
    • They feature a main stage for high-flow operation and a smaller, proportional stage for fine control.
    • The main stage is typically actuated hydraulically by a pilot control pressure, while the proportional stage is actuated by an electrical input signal.
    • Servo proportional valves offer high dynamic response, accuracy, and flow capacity, making them suitable for demanding applications such as aircraft flight control systems and industrial automation.
The operation of hydraulic servo valves involves several key components and principles:
  1. Spool or Poppet Mechanism:
    • The spool or poppet inside the servo valve body controls the flow or pressure of hydraulic fluid by regulating the flow area through which the fluid can pass.
    • The position of the spool or poppet is controlled by an actuator, such as a proportional solenoid or torque motor.
  2. Electromechanical Actuation:
    • Proportional solenoids or torque motors actuate the spool or poppet in response to an electrical input signal.
    • The electrical signal controls the position or force of the actuator, which in turn positions the spool or poppet to achieve the desired flow rate or pressure.
  3. Feedback Mechanism:
    • Many hydraulic servo valves incorporate feedback mechanisms, such as LVDTs (Linear Variable Differential Transformers) or potentiometers, to provide position or pressure feedback.
    • The feedback signal is used to verify the position of the spool or poppet and provide closed-loop control for accurate positioning and compensation for external disturbances.
  4. Hydraulic Amplification:
    • Hydraulic servo valves amplify the input signal to provide precise control over hydraulic actuators with large forces or displacements.
    • They achieve amplification through the use of high-pressure hydraulic fluid and mechanical advantage provided by the valve design.
Overall, hydraulic servo valves offer high-performance control capabilities for a wide range of hydraulic systems, enabling precise positioning, speed control, and force control in demanding applications.
