INVT Drives
437
Apr 13, 2024 10:17 am
Cause : Autotuning fault indicate that the motor capacity does not comply with the inverter capability and the rated parameter of the motor does not set correctly.
- The offset between the parameters from autotune and the standard parameter is huge.
- Change the inverter mode.
- Set the rated parameter according to the motor name plate.
- Check the motor connection and set the parameter.
