What is Fault Tolerant Ethernet (FTE)?
Fault Tolerant Ethernet (FTE) is a networking technology designed to provide high availability and redundancy in industrial Ethernet networks. It is specifically tailored for use in critical applications where network downtime can have significant consequences, such as industrial automation, process control, and power distribution systems.
The main goal of Fault Tolerant Ethernet is to ensure uninterrupted operation of the network even in the event of network failures, such as cable breaks, device failures, or network switch malfunctions. FTE achieves this by employing redundant network paths, automatic failover mechanisms, and real-time monitoring to detect and recover from faults quickly.
Key features of Fault Tolerant Ethernet include:
  1. Redundant Network Paths: FTE networks typically use redundant network paths to provide multiple communication routes between network devices. Redundant paths help ensure that data can still be transmitted even if one path becomes unavailable due to a fault or failure.
  2. Automatic Failover: FTE systems incorporate automatic failover mechanisms that detect network faults and automatically reroute traffic along alternative paths. This helps minimize network downtime and ensures continuous communication between devices.
  3. Parallel Redundancy Protocol (PRP): PRP is a standardized redundancy protocol used in Fault Tolerant Ethernet networks. It duplicates every data frame and sends each copy along separate network paths. At the receiving end, the duplicate frames are compared, and only the error-free frame is forwarded to the application layer. PRP provides zero-time recovery from network failures and ensures high reliability and fault tolerance.
  4. High Availability: Fault Tolerant Ethernet networks are designed to provide high availability and reliability, with built-in redundancy and failover mechanisms that minimize the impact of network faults on system operation. This helps maximize uptime and maintain continuous operation of critical industrial processes.
  5. Real-Time Monitoring: FTE systems typically include real-time monitoring capabilities that continuously monitor the health and status of the network. This allows operators to quickly identify and troubleshoot network issues before they impact system performance.
  6. Scalability: Fault Tolerant Ethernet networks can be scaled to accommodate growing network requirements and expanding industrial automation systems. Additional redundant paths and network devices can be added as needed to increase fault tolerance and redundancy.
Overall, Fault Tolerant Ethernet is a robust and reliable networking technology that provides high availability and fault tolerance for critical industrial applications. By incorporating redundant paths, automatic failover mechanisms, and real-time monitoring, FTE helps ensure continuous operation of industrial Ethernet networks even in the face of network failures and faults.
