F0003 fault in siemens micromaster 440 or MM440 drive
How can resolve problem F0003 fault in siemens micromaster 440 or MM440 drive ?
Cause : UnderVoltage.
- Main supply failed.
- Shock load outside specified limits.
Diagnosis & Remedy
Check the following:
- Supply voltage (P0210) must lie within limits indicated on rating plate.
- Supply must not be susceptible to temporary failures or voltage reductions.
