E.PE6 fault error code in Mitsubishi F800
Cause : Internal storage device fault- This protective function is activated by an inverter reset if writing data fails due to power-OFF or a data fault occurs in the storage device during parameter operations.
  1. Check if the power was turned OFF during parameter operations.
  2. Check the power supply or the devices on the power system to check that the devices have no fault
