Er1 fault error code in Mitsubishi F700
Cause : Parameter write error comes when parameter setting was attempted while Pr.77 Parameter write selection is set to disable parameter write. Overlapping range has been set for the frequency jump.
  1. Check the Pr.77 Parameter write selection setting.
  2. Check the settings of Pr.31 to Pr.36 (frequency jump). (
  3. Check the settings of Pr.100 to Pr.109 (adjustable 5 points V/F).
  4. Check the connection of PU and the inverter.
  5. Check the Pr.72 PWM frequency selection setting.
