Err4 Current Zero Excursion Malfunction fault in parker AC10 drive
Cause : Current Zero Excursion Malfunction comes when a problem with the drive's current sensing or control circuitry. This error can occur when the drive fails to detect a current zero crossing, which is a critical point in the motor's commutation process.
Err4 fault in parker AC10 drive indicate Current Zero Excursion Malfunction. This means the drive has detected an abnormality in the current sensing circuitry, where the current is not behaving as expected during zero-crossing points.
Steps to Troubleshoot "Current Zero Excursion Malfunction":
  1. Check Motor Wiring and Connections:
    • Inspect all motor wiring and connections for any loose, damaged, or improperly connected cables.
    • Ensure that the motor cables are properly shielded and grounded to minimize electrical noise, which can affect current sensing.
  2. Inspect the Motor:
    • Verify the condition of the motor, checking for any internal faults like short circuits or ground faults.
    • Use a multimeter to measure the insulation resistance of the motor windings to ensure there are no leaks.
  3. Examine the Drive’s Output:
    • Check the drive’s output phases (U, V, W) for any signs of short circuits or irregular resistance values.
    • Ensure that there is no phase imbalance or issues with the drive's output stage.
  4. Check Current Sensor Integrity:
    • The drive relies on current sensors to monitor the motor's current. A fault in these sensors or associated circuitry can lead to a zero excursion malfunction.
    • If you have access, check the condition of the current sensors inside the drive. However, this typically requires technical expertise or professional service.
  5. Minimize Electrical Noise:
    • Electrical noise can interfere with the current sensing process. Make sure the motor cables are not running parallel to power lines or other sources of electromagnetic interference (EMI).
    • Use proper grounding techniques and ensure that all shields on cables are correctly terminated.
