Schneider Drives
439
Jul 19, 2024 12:57 pm
Cause : Overbraking comes when the drive is subjected to excessive braking, either due to sudden load changes or improper braking configuration. This fault comes due to the rapid deceleration or stopping of a heavy load can cause overbraking.
"F009" fault in Schneider drive indicate "overbraking" condition. This means the drive is subjected to excessive braking, either due to sudden stops or heavy loads.
Follow these steps to correct this fault:
- Check Load Conditions: Analyze the load profile and identify any sudden load changes.
- Adjust Deceleration Time: Increase the deceleration time to allow for smoother braking.
- Verify Braking Resistor: Ensure the braking resistor is correctly sized for the application.
- Review Drive Parameters: Check the drive's braking parameters and adjust them as needed.
- Consider Braking Choppers: If the issue persists, consider using braking choppers to dissipate braking energy.
