Siemens Drives
7,023
May 11, 2024 10:35 am
Cause : Motor data identification activated comes when the motor data identification routine is activated or the motor data identification routine is carried out at the next power-on command.
A7991 is a fault code displayed on Siemens drives, specifically in the Sinamics G120 model series. This code indicates that the motor data identification process is activated.
- If rotating measurement is selected, it will not be possible to save the parameter assignment.
- Once motor data identification has been completed or de-activated, the option to save the parameter assignment will be made available again.
The alarm automatically disappears after the motor data identification routine has been successfully completed.
