F08501 PROFINET Setpoint Timeout Fault in Siemens Drive
[#21030]
F08501 – PROFINET: Setpoint Timeout in a Siemens Drive indicates that the drive has stopped receiving speed, torque, or other control setpoints from the PROFINET controller (PLC) within the configured monitoring time. The drive continuously monitors cyclic communication with the PROFINET master. If no valid setpoint telegram is received before the timeout expires, the drive generates Fault F08501 to prevent uncontrolled motor operation.
This fault is commonly caused by a PROFINET communication interruption, PLC in STOP mode, or an incorrect setpoint monitoring time.
Possible Causes
  • PROFINET communication cable disconnected.
  • PROFINET network connection interrupted.
  • PLC (PROFINET controller) switched OFF.
  • PLC in STOP mode.
  • Network switch failure.
  • Damaged Ethernet cable or connector.
  • Incorrect PROFINET device configuration.
  • Incorrect IP address or device name.
  • Excessive network communication delay.
  • Setpoint monitoring time set too short.
  • Communication interference or packet loss.
  • Drive PROFINET communication module fault.
  • PLC program not transmitting cyclic setpoints.
  • Internal communication hardware fault.
Solutions
  • Restore the PROFINET network connection.
  • Verify that the PLC (PROFINET controller) is powered ON.
  • Set the PLC to RUN mode.
  • Check the Ethernet cable and connectors.
  • Verify that the drive and PLC are communicating normally.
  • Check the PROFINET device name and IP address configuration.
  • Inspect network switches and communication equipment.
  • Verify that the PLC program is transmitting cyclic setpoints.
  • Increase the Setpoint Monitoring Time if communication delays are expected.
  • Reset the drive after communication has been restored.
  • Replace defective communication hardware if necessary.
Additional Information
Siemens drives operating over PROFINET rely on cyclic communication with the PLC (IO Controller) to receive:
  • Speed reference
  • Torque reference
  • Position commands
  • Control words
The drive continuously monitors the arrival of these cyclic telegrams. If communication is interrupted for longer than the configured timeout period, the drive generates F08501 – PROFINET: Setpoint Timeout.
According to Siemens, the most common causes are:
  • Bus connection interrupted
  • Controller switched OFF
  • Controller in STOP mode
If the communication network is functioning correctly but the fault still occurs, Siemens recommends checking the setpoint monitoring time, as an excessively short timeout may cause nuisance trips during temporary communication delays.
Common Symptoms
  • Drive displays F08501.
  • Motor stops unexpectedly.
  • Drive cannot receive speed reference.
  • PLC communication fault indication.
  • PROFINET communication lost.
  • Drive trips after PLC enters STOP mode.
  • Network communication alarm.
  • Fault clears after communication is restored.
  • Drive cannot restart until the PLC returns to RUN mode.
Recommended Troubleshooting Sequence
  1. Verify that the PLC is powered ON.
  2. Confirm the PLC is in RUN mode.
  3. Check the PROFINET Ethernet cable.
  4. Inspect Ethernet connectors for damage.
  5. Verify the network switch is operating correctly.
  6. Confirm the drive appears online in the PLC hardware configuration.
  7. Verify the PROFINET device name and IP address.
  8. Check that the PLC program is transmitting cyclic control words and setpoints.
  9. Inspect the network for communication delays or packet loss.
  10. Increase the Setpoint Monitoring Time if necessary.
  11. Reset the drive and verify communication.
  12. Replace faulty communication hardware if the fault persists.
F08501 Check Table
Check Point Action
PLC power Verify controller is powered ON
PLC operating mode Set controller to RUN
PROFINET cable Inspect for damage or loose connection
Ethernet connectors Check secure connection
Network switch Verify proper operation
Device name Confirm correct PROFINET device name
IP address Verify network configuration
PLC program Ensure cyclic setpoints are transmitted
Setpoint monitoring time Increase if communication delays occur
Communication module Replace if defective
Preventive Maintenance Tips
  • Periodically inspect PROFINET cables and connectors.
  • Secure Ethernet cables to prevent accidental disconnection.
  • Verify PLC remains in RUN mode during operation.
  • Maintain reliable industrial Ethernet switches.
  • Back up the PROFINET device configuration after commissioning.
  • Monitor network diagnostics for communication errors.
  • Configure an appropriate setpoint monitoring timeout for the application.
  • Keep firmware versions of the PLC and drive compatible.
  • Record recurring communication faults for network analysis.
  • Investigate repeated F08501 faults promptly to prevent unexpected production interruptions.
Proper maintenance of the PROFINET network, verification of the PLC RUN status, inspection of Ethernet cables and communication hardware, correct configuration of the PROFINET device name and IP address, and appropriate adjustment of the setpoint monitoring time will help prevent recurring F08501 PROFINET: Setpoint Timeout Faults in Siemens drives, ensuring reliable communication and stable motor control.
