f7950 siemens
Cause : Motor parameter incorrect comes when the motor parameters were incorrectly entered while commissioning.
In a Siemens Sinamics drive, fault code F7950 indicates an "Incorrect motor parameter" error. This means the drive detects a mismatch between the parameters configured for the motor and the data stored within the drive itself.
Here's a breakdown of the issue and some troubleshooting steps to help you resolve it:
Possible Causes of F7950 Error:
  • Motor Data Mismatch: The most common cause is a discrepancy between the actual motor data (like motor power, voltage, current rating) and the parameters entered during the drive's commissioning process. This mismatch can occur due to:
  • Using incorrect motor nameplate data when configuring the drive.
  • Data entry errors during commissioning.
  • Geared Motors: When using geared motors without DRIVE CLiQ encoders (Siemens proprietary encoder system), this fault can occur due to an incorrect "motor rated power factor" parameter setting.
1. Verify Motor Nameplate Data:
  • Locate the motor nameplate, which typically displays the motor's rated power, voltage, current, and other specifications.
  • Compare this data with the motor parameters entered during the drive's commissioning process. Ensure all values match exactly.
2. Review Commissioning Settings:
  • Refer to the Siemens Sinamics drive manual for your specific model. It should have instructions on how to access and review the motor parameters.
  • Double-check all the entered motor data for any typos or inconsistencies.
3. Check for Geared Motor Setting (if applicable):
  • If you're using a geared motor without DRIVE CLiQ encoders, consult the Siemens manual for instructions on correcting the "motor rated power factor" parameter setting for this specific configuration.
