Siemens SIMOVERT Master Drive
706
Jun 29, 2024 4:57 am
Cause : Following error in motion- This alarm comes when the following error limit for motion was exceeded during a traversing movement:
- Following error monitoring - in motion (machine data 15) was entered incorrectly.
- The mechanical system cannot follow the commands of the position controller.
- Actual position value invalid
- Incorrect optimization of the position controller or speed controller.
- The mechanical system is sluggish or blocked.
Follow these steps to correct the alarm:
- Check and correct the machine data.
- Check the actual position value (speed- controlled operation); check position encoder, evaluator module and encoder lead.
- Optimize the position controller or the speed controller.
- Check the mechanical system.
