ope02 yaskawa
Cause: Parameter Range Setting Error comes when one or more parameters in the drive have been programmed with a value that exceeds the permissible upper or lower limit for that specific parameter.
ope02 yaskawa indicates a Parameter Range Setting Error. This occurs when a parameter is set outside its allowable range, which can prevent the drive from operating correctly.
  • Identify the specific parameter: If possible, try to recall which parameter you were setting when the OPE02 alarm appeared. This will help narrow down the issue.
  • Check recent changes: If you're unsure which parameter is causing the issue, review all the parameters that have been changed recently.
  • Consult the manual: The parameter manual for your specific Yaskawa drive model is the most important resource. It will list all the parameters and their valid setting ranges.
