bUSy alarm fault code in yaskawa GA500 drive
Cause : Busy- You set the drive to use MEMOBUS/Modbus communications to change parameters, but you used the keypad to change parameters.
  1. Use MEMOBUS/Modbus communications to enter the enter command, then use the keypad to change the parameter.
  2. You tried to change a parameter while the drive was changing setting.
  3. Wait until the process is complete.
