Yaskawa E7, G7, GA800 & GA500 Drive
346
Mar 19, 2024 12:13 pm
Cause : Output Phase Loss comes when an open-phase occurred at the Inverter output. This fault is detected when L8-07 is set to 1 or 2.
- There is a broken wire in the output cable.Â
- There is a broken wire in the motor- winding.
- The output terminals are loose.
- Reset the fault after correcting its cause.
- The motor being used has a capacity less than 5% of the rated output current.
- Check the motor and Inverter capacity.
