oC fault code in yaskawa R1000 drive
Cause : Overcurrent comes when the current drawn by the motor exceeds the set threshold. This can happen due to various reasons, including:
  1. Mechanical Jam or Load: If the motor is mechanically jammed or the load is too high, it can cause the motor to draw excessive current.
  2. Incorrect Parameter Settings: Incorrect settings in the drive parameters, such as current limits or acceleration/deceleration values, can lead to overcurrent faults.
  3. Short Circuit or Ground Fault: A short circuit in the motor windings or a ground fault can cause excessive current flow.
  4. Motor Compatibility: The motor may not be compatible with the drive, or there could be mismatched parameters between the drive and the motor.
  5. Power Supply Issues: Problems with the power supply, such as voltage fluctuations or insufficient power, can cause overcurrent faults.
Here are some steps you can take to troubleshoot and resolve the issue:
  1. Check Mechanical System: Ensure that the motor is not mechanically jammed and that the load is appropriate for the motor.
  2. Verify Parameter Settings: Double-check the parameter settings in the drive to ensure they are configured correctly for your application.
  3. Inspect Wiring: Inspect the wiring between the drive, motor, and power supply for any signs of damage, loose connections, or short circuits.
  4. Test Motor: Test the motor separately to ensure it is functioning correctly and within its specified parameters.
  5. Review System Integration: Verify that the motor is compatible with the drive and that all system components are properly integrated.
  6. Reset Faults: If the fault persists after troubleshooting, reset the fault in the drive and observe for any recurring issues.
