Yaskawa Z1000, L1000A, L1000E & V1000 Drive
294
Mar 29, 2024 5:10 am
Cause : Speed Deviation comes when the deviation between the speed reference and speed feedback is greater than the setting in F1-10 for longer than the time in F1-11.
- Load is too heavy Reduce the load.
- Accel/decel ramp is too short.
- Increase the acceleration and deceleration times (C1-01 through C1-08).
- The load is locked up.
- Check the machine.
- Parameter settings are inappropriate.
- Check the settings of parameters F1-10 and F1-11.
- The motor brake is not applied.
- Ensure the motor brake operates properly with a brake control command from the drive.
