Yaskawa Z1000, L1000A, L1000E & V1000 Drive
297
Mar 29, 2024 6:43 am
Cause : Overacceleration Detection comes when the acceleration of the elevator car exceeds the overacceleration detection level (S6-10).
- The encoder offset needs to be adjusted whenever the encoder is replaced or when reversing the direction of the motor.
- Noise along the encoder cable.
- Cables for the motor encoder are not wired properly, or the PG option card (or the encoder itself) is damaged.
- Check the encoder wiring for any loose connections.
- Make sure that the shielded line is properly grounded.
