Convert your height from feet and inches to centimeters (cm) instantly. High-precision height converter with a conversion table, height formula, and common height references.
Height Converter
Imperial (ft/in) to Metric (cm)
The Height Conversion Formula
Height conversion from the Imperial system (Feet and Inches) to the Metric system (Centimeters) requires two steps. First, you convert the entire height into inches, then multiply by the international standard factor.
Step 1: Total Inches = (Feet × 12) + Inches
Step 2: Centimeters = Total Inches × 2.54
Example: If you are 6 feet 0 inches tall: (6 × 12) + 0 = 72 inches. Then, 72 × 2.54 = 182.88 cm.
Height Conversion Table (Quick Reference)
Find your height in centimeters quickly with this common height chart:
| Feet & Inches | Centimeters (cm) | Meters (m) |
| 5' 0" | 152.40 cm | 1.52 m |
| 5' 5" | 165.10 cm | 1.65 m |
| 5' 8" | 172.72 cm | 1.73 m |
| 5' 10" | 177.80 cm | 1.78 m |
| 6' 0" | 182.88 cm | 1.83 m |
| 6' 2" | 187.96 cm | 1.88 m |
Why Convert Height to Centimeters?
While Feet and Inches are commonly used in the United States and the United Kingdom for personal height, the rest of the world and the scientific community use Centimeters.
- Medical Records: Most medical journals and hospital records require height in metric for Body Mass Index (BMI) calculations.
- Travel & Documentation: International visas and passports often require height in centimeters.
- Aviation & Sports: Pilot applications and international athletic drafting often use centimeters for precise uniform and equipment sizing.
Using an automated height converter ensures you avoid manual calculation errors, especially since the "base 12" system of feet is significantly different from the "base 10" metric system.
