Convert Henry (H) to Exahenry (EH) instantly. Includes the conversion formula, a quick reference table, and technical context on SI inductance units.
Inductance Converter
The Conversion Formula
To convert from Henry (H) to Exahenry (EH), you divide the value by 1,000,000,000,000,000,000 (one quintillion). In scientific terms, this is expressed as multiplying by 10 to the power of negative 18.
Exahenry (EH) = Henry (H) × 10⁻¹⁸
Quick Reference Table
| Henry (H) | Exahenry (EH) |
| 1 H | 1.0 × 10⁻¹⁸ EH |
| 1,000 H | 1.0 × 10⁻¹⁵ EH |
| 1,000,000 H | 1.0 × 10⁻¹² EH |
| 1,000,000,000,000,000,000 H | 1 EH |
Contextual Information
What is a Henry?
The Henry (H) is the International System of Units (SI) derived unit of electrical inductance. It is named after the American scientist Joseph Henry. If the rate of change of current in a circuit is one ampere per second and the resulting electromotive force is one volt, then the inductance of the circuit is one henry.
What is an Exahenry?
The Exahenry (EH) is a massive multiple of the Henry. The prefix “exa” represents a factor of 10¹⁸. Because a Henry is already a relatively large unit for everyday electronics (where millihenrys or microhenrys are common), an Exahenry is an astronomical value, used almost exclusively in theoretical physics or advanced computational modeling of massive magnetic systems.
Why is this conversion important?
While engineers rarely encounter Exahenrys in the field, understanding the relationship between base SI units and their prefixes is fundamental to physics and metrology. This converter allows for the scaling of standard measurements into the exa-scale framework for scientific documentation and large-scale inductive analysis.
