Hitachi WJ-C1 Fault Codes & Troubleshooting List 2026 – Troubleshoot your Hitachi WJ-C1 compact inverter with our updated 2026 guide. Learn to interpret E01-E60 trips, use ProDriveNext diagnostics, and reset faults to minimize downtime.
The Hitachi WJ-C1 is a compact, space-saving inverter designed for versatile industrial applications. It combines ease of use with robust protective functions. When the drive detects an anomaly—whether it’s an electrical surge or a mechanical overload—the 4-digit LED display on the front panel will flash a trip code starting with “E” (e.g., E01, E07, E09).
This guide provides the most up-to-date resources for 2026 to help you interpret these codes and restore your production line efficiently.
WJ-C1 Fault Codes Reference Table
Below is the complete list of protective functions and alarm codes for the WJ-C1. Please refer to this table to match the alphanumeric code on your display with the specific diagnostic remedy.
| Fault Code and Meaning | Cause and Remedy |
| E01.* Over current error (Constant speed) | Cause:
| E02.* Over current error (During deceleration) | Cause: Rapid deceleration. Remedy:
| E03.* Over current error (During acceleration) | Cause:
| E04.* Over current error (Other) | Cause: Is DC braking high? Remedy:
| E05.* Overload error | Cause:
| E06.* Braking resistor overload error | Cause:
| E07.* Overvoltage error | Cause:
| E08.* Memory error | Cause:
| E09.* Undervoltage error | Cause:
| E10.* Current detector error | Cause: Inverter failure. Remedy:
| E11.* CPU error | Cause:
| E12.* External trip error | Cause:
| E13.* USP error | Cause: Is the power supply turned on with the RUN command input? Remedy:
| E14.* Ground fault | Cause:
| E15.* Power supply overvoltage error | Cause: Is the power supply voltage too high? Remedy:
| E19.* Temperature detection error | Cause: Inverter failure. Remedy:
| E21.* Cooling fin temperature error | Cause:
| E22.* CPU communication error | Cause:
| E25.* Main circuit error | Cause:
| E26.* Analog current input error | Cause:
| E30.* Driver error | Cause:
| E35.* Thermistor error (Motor temperature error) | Cause:
| E36.* Brake error | Cause:
| E37.* STO shut-off error | Cause:
| E38.* Low-speed range overload error | Cause: Is the load too heavy? Remedy:
| E40.* Remote operator communication error | Cause: Is there a communication error? Remedy:
| E41.* Modbus communication error | Cause:
| E43.* EzSQ invalid instruction error | Cause: Invalid instruction detected in EzSQ program. Remedy:
| E44.* EzSQ nesting count error | Cause: Nesting count exceeds allowable executed number. Remedy:
| E45.* EzSQ execution error | Cause: Instruction that cannot be executed is detected. Remedy:
| E50.* to E59.* EzSQ user-assigned error 0 to 9 | Cause: Corresponding user-assigned tripping programs executed in EzSQ. Remedy:
| E60.* to E69.* Option related error | Cause:
| E80.* Encoder disconnection error | Cause:
| E81.* Overspeed error | Cause:
| E83.* Position control range error | Cause: Is the current position and home position correct? Remedy:
| E98.* ST1/ST2 mismatch error | Cause:
| E99.* STO internal failure error | Cause: Is the safety function working properly? Remedy:
How to Read WJ-C1 Faults via ProDriveNext
While the integrated keypad is sufficient for basic identification, connecting your PC to the WJ-C1 using ProDriveNext software provides professional-grade diagnostic data for 2026 maintenance standards.
- Fault History (d081 to d086): The WJ-C1 records the last 6 trip events. You can access these via the keypad by navigating to the Monitor (d) group. Parameter d081 displays the most recent fault.
- Trip Status Details: When viewing a trip in d081, the display alternates between the fault code and the electrical status of the drive at the moment of failure, including output frequency, motor current, and DC bus voltage.
- Software Trace: ProDriveNext allows you to view the “Fault Monitor” window, which graphs the current and voltage leading up to a trip, making it easier to identify if a E01 (Overcurrent) trip was caused by a mechanical jam or a logic error.
General Troubleshooting Steps
Before performing a manual reset on your Hitachi WJ-C1, perform these essential hardware checks:
- Overcurrent (E01 – E04): Check for short circuits in the motor wiring. If the trip happens during acceleration, try increasing the Acceleration Time (Parameter F002) or checking for mechanical binding on the motor shaft.
- Overvoltage (E07): This usually occurs during rapid deceleration of a high-inertia load. Increase the Deceleration Time (Parameter F003) or check the input AC line for voltage spikes.
- Under-voltage (E09): Check the stability of your power supply. This trip is common in facilities where the power sags when larger machinery starts up on the same circuit.
Q: How do I reset a fault on the Hitachi WJ-C1?
A: Once the cause of the trip is resolved, you can reset the drive using one of these methods:
- Press the Stop/Reset key on the front keypad.
- Activate the digital input terminal assigned to the RS (Reset) function (Terminal 4 or 5 depending on setup).
- Cycle the main input power (Wait until the display goes completely dark before turning the power back on).
Q: What is the “USP” error on my Hitachi WJ-C1?
A: USP (Unattended Start Protection) is a safety feature. It prevents the motor from starting automatically if the Run command is already active when you power up the drive. Simply turn the Run command OFF to clear the message.
Q: Why does my drive show “E14” (Ground Fault)?
A: E14 indicates that current is leaking to the earth on the output side. This is often caused by damaged motor insulation or moisture in the conduit. Do not ignore this trip, as it can cause damage to the drive’s internal power modules.
Q: Where is the fault history stored?
A: You can find the history of the last 6 faults in the Monitor (d-group), specifically parameters d081 through d086. Each entry provides a snapshot of the inverter’s electrical data at the time of the error.
