Online Tools & Converters – Welcome to your one-stop destination for daily calculations and conversions. Whether you are a student, engineer, developer, or just need to convert a recipe, we have a tool for you. Browse our comprehensive categories below to find exactly what you need.
Select Category
Below list show all online tools & converters:
All-in-One Tools & Converters List
| Tool Name ⇅ | Category ⇅ |
No tools found matching your search.
CATEGORIZED CONTENT LIST
⚡ Electrical Calculators
Essential tools for electricians, engineers, and students.
- Amps to kVA calculator
- Amps to kW calculator
- Amps to VA calculator
- Amps to volts calculator
- Amps to watts calculator
- Electricity bill calculator
- Energy consumption calculator
- Energy cost calculator
- Joules to volts calculator
- Joules to watts calculator
- kVA to amps calculator
- kVA to kW calculator
- kVA to watts calculator
- kW to amps calculator
- kW to kWh calculator
- kW to volts calculator
- mAh to Wh calculator
- Ohms Law calculator
- Power factor calculator
- Voltage drop calculator
- Watts to amps calculator
- Watts to volts calculator
- Wh to mAh calculator
- Wire gauge calculator
📐 Math & Scientific Calculators
Solve complex problems instantly.
- Antilog calculator
- Average calculator
- Exponents calculator
- Factorial calculator
- Fraction calculator
- GCD / LCM calculator
- Log calculator
- Online Abacus
- Percentage calculator (Math)
- Pythagorean theorem calculator
- Quadratic equation solver
- Random number generator
- Scientific calculator
- Square root calculator
- Standard deviation calculator
- Triangle calculator (Right)
- Trigonometry calculator (Sin/Cos/Tan)
- Variance calculator
💰 Financial Calculators
Manage your money and plan for the future.
- Compound interest calculator
- Discount calculator
- Effective interest rate calculator
- GST calculator
- Mortgage calculator
- Percentage calculator (Financial)
- Percentage change calculator
- Salary Converter (Hourly to Yearly)
- Simple interest calculator
- Tip Calculator
- VAT calculator
📝 Text, PDF & Web Tools
Utilities for developers, writers, and content creators.
- Case converter
- Character counter
- Image to PDF converter
- JPG to PDF converter
- Line counter
- Online notepad
- Password generator
- PDF viewer / reader
- PNG to PDF converter
- QR Code Generator
- RGB color codes
- Word counter
- Word frequency
📏 Length & Distance Converters
Convert metric to imperial and back.
- cm to feet
- cm to feet+inches
- cm to inches
- cm to km
- cm to meters
- cm to miles
- cm to mm
- cm to yard
- Feet to cm
- Feet to feet+inches
- Feet to inches
- Feet to km
- Feet to meters
- Feet to miles
- Feet to mm
- Height converter
- Inches to cm
- Inches to feet
- Inches to meters
- Inches to mm
- km to meters
- km to miles
- Meters to feet
- Meters to inches
- Meters to miles
- Miles to km
- mm to inches
- Ring Size Converter
- Yards to meters
⏱️ Time & Date Tools
Keep track of time across the globe.
- Age calculator
- Alarm Clock
- Birthday calculator
- Countdown Timer
- Date calculator
- Days in a year calculator
- Seconds in a day calculator
- Stopwatch
- Time calculator
⚖️ Weight, Mass & Volume
- Barrels to Gallons
- Carats to Grams
- Cubic Meters to Liters
- Cups to Tablespoons
- Cups to Teaspoons
- Grams to Ounces
- Kilograms to Pounds (kg to lbs)
- Liters to Gallons (UK)
- Liters to Gallons (US)
- Metric Ton to Kilogram
- Milligrams to Grams
- Milliliters (ml) to Ounces
- Ounces to Grams
- Pounds to Kilograms (lbs to kg)
- Stone to Pounds
- Tablespoons to Teaspoons
💾 Data & Number Base Converters
- ASCII to Binary converter
- ASCII to Hex converter
- Base converter
- Binary converter
- Binary to Decimal converter
- Binary to Hex converter
- Binary to String converter
- Bits to Bytes
- Bytes to Kilobytes (KB)
- Data Transfer Rate Calculator
- Decimal to Binary converter
- Decimal to Hex converter
- Decimal to Octal converter
- GB to TB Converter
- Hex to ASCII converter
- Hex to Binary converter
- Hex to Decimal converter
- KB to Megabytes (MB)
- Roman numerals converter
- Scientific notation converter
🌡️ Temperature & Pressure
- Atmospheres (atm) to Pascals
- Bar to PSI
- Celsius to Fahrenheit
- Celsius to Kelvin
- Fahrenheit to Celsius
- Fahrenheit to Kelvin
- Inches of Mercury (inHg) to Millibars
- Pascal to PSI
💡 Energy & Light
- BTU to Joules conversion
- BTU to kJ conversion
- Calories to Joules conversion
- Candela to lumens calculator
- Candela to lux calculator
- eV to GeV conversion
- eV to Joules conversion
- Footcandles to lux calculator
- Home Energy Calculator
- Joules to BTU conversion
- Joules to Calories conversion
- Joules to eV conversion
- Joules to kJ conversion
- Joules to kWh conversion
- kJ to BTU conversion
- kJ to calories conversion
- kJ to Joules conversion
- kWh to Joules conversion
- Lumens to candela calculator
- Lumens to lux calculator
- Lumens to watts calculator
- Lux to candela calculator
- Lux to footcandles calculator
- Lux to lumens calculator
- Lux to watts calculator
- MPG to L/100km (Fuel Econ)
- Watts to lumens calculator
- Watts to lux calculator
🎓 Grade & GPA Calculators
- College GPA calculator
- Final grade calculator
- GPA to letter grade conversion
- Grade calculator
- High school GPA calculator
- Letter grade to GPA conversion
🚗 Speed & Fuel
- Knots to MPH
- KPH to MPH
- Mach Number Converter
- Meters per second (m/s) to km/h
- MPH to KPH (Miles per hour to km/h)
🗺️ Area
- Acres to Hectares
- Hectares to Acres
- Square Feet to Square Meters
- Square Kilometers to Square Miles
- Square Meters to Square Feet
- Square Yards to Square Meters
