ABB DCS880 Drive
2
717
Dec 25, 2021 8:55 am
How can resolve problem F513 Mains overvoltage Fault In ABB DCS880 ?
Dec 25, 2021 8:56 am
Too high voltage on the mains/AC side. The actual mains
voltage is > 1.3 * 99.10 Nominal mains voltage for longer than
10 s while Ready run = 1.
Check:
− If the mains voltage is within the set tolerance.
− If the mains voltage scaling is correct. See 99.10 Nominal
mains voltage.
− The cutting of the voltage coding resistors on the SDCS-
PIN-H51.
