What is ABB fault c...
What is ABB fault code 3381 ?
ABB fault code 3381 - comes when you start drive without motor or small rating motor as compare to drive then output phase loss fault comes.
Cause : When you start drive without motor or small rating motor as compare to drive then output phase loss fault comes. Need to check motor data in drive and check motor rating. These are the steps for fault correction :
1. Check motor wiring and cable.
2. Check Motor data in drive parameter.
3. Check the rating of motor - if small rating motor connected as compare to drive then this fault come.
4. If motor not connected then connect motor and check.
Here is list of ABB drive faults :
Click here for ABB ACS380 drive
https://click2electro.com/forum/abb-acs380-drive/3381-output-phase-loss-fault-in-abb-acs380-drive/#post-2046
Click here for ABB ACS880 drive
https://click2electro.com/forum/abb-acs880-drive/3381-output-phase-loss-fault-in-abb-acs880-drive/#post-1714
Click here for ABB ACS580 drive
https://click2electro.com/forum/abb-acs580-drive/3381-output-phase-loss-fault-in-abb-acs580-drive/
Click here for ABB ACS560 drive
https://click2electro.com/forum/abb-acs560-drive/3381-output-phase-loss-fault-in-abb-acs560-drive/
