Unidrive M400 Drive Fault Codes (2026) – Comprehensive 2026 troubleshooting guide for Nidec Control Techniques Unidrive M400. Learn to interpret plain-text trip codes, troubleshoot PLC errors, and use Connect software.
The Nidec Control Techniques Unidrive M400 is a high-performance general-purpose drive designed for advanced system integration. A key feature that sets the M400 apart from its smaller siblings is the multi-language LCD keypad, which provides plain-text descriptions of trips rather than just abbreviations. When a failure occurs, the drive stops the motor and displays a mnemonic trip code—such as OI.AC (Overcurrent) or It.AC (Motor Overload)—accompanied by a helpful description.
This 2026 guide is designed to help you navigate the diagnostic depth of the M400, manage its onboard PLC features, and utilize advanced software tools to restore system operation.
Unidrive M400 Fault Codes Reference Table
Below is the reference list for the Unidrive M400. While the LCD keypad provides descriptions, you can use this table to cross-reference technical causes and corrective actions.
| Fault Code and Meaning | Cause and Remedy |
| 28 An Input 1 Loss | Cause: Current loss detected in current mode on Analog input 1 (Terminal 2). In 4-20 mA and 20-4 mA modes, loss is detected if current falls below 3 mA. Remedy:
| 189 An Input 1 OI | Cause: Analog input 1 over-current. Current input on analog input 1 exceeds 24mA. Remedy:
| 29 An Input 2 Loss | Cause: Current loss detected in current mode on Analog input 2 (Terminal 5). In 4-20 mA and 20-4 mA modes, loss is detected if current falls below 3 mA. Remedy:
| 190 An Input 2 OI | Cause: Analog input 2 over-current. Current input on analog input 2 exceeds 24 mA. Remedy:
| 11 Autotune 1 | Cause: Required speed could not be reached during autotune. Sub-trip 2: The motor did not reach the required speed during rotating autotune or mechanical load measurement. Remedy:
| 13 Autotune 3 | Cause: Measured inertia has exceeded the parameter range (RFC-A mode only). Sub-trip 1: Measured inertia exceeded range. Sub-trip 3: Mechanical load test unable to identify motor inertia. Remedy:
| 18 Autotune Stopped | Cause: Autotune test stopped before completion because drive enable or drive run were removed. Remedy:
| 19 Brake R Too Hot | Cause: Braking resistor overload timed out (I2t). The Braking Resistor Thermal Accumulator (10.039) has reached 100%. Remedy:
| 185 Card Access | Cause: NV Media Card Write fail. The drive was unable to access the card, or data transfer was corrupted/incomplete. Remedy:
| 178 Card Busy | Cause: NV Media Card cannot be accessed as it is being accessed by an option module. Remedy:
| 188 Card Compare | Cause: NV Media Card file/data is different to the one in the drive. A compare has been carried out and differences found. Remedy:
| 179 Card Data Exists | Cause: Attempt made to store data on an NV Media Card in a data block which already contains data. Remedy:
| 187 Card Drive Mode | Cause: NV Media Card parameter set not compatible with current drive mode. The drive mode in the data block is different from the current drive mode. Remedy:
| 182 Card Error | Cause: NV Media Card data structure error. Sub-trip 1: Required folder/file structure not present. Sub-trip 2: The 000.DAT file is corrupted. Sub-trip 3: Two or more files in the MCDF folder have the same ID. Remedy:
| 184 Card Full | Cause: NV Media Card full. Not enough space left on the card. Remedy:
| 183 Card No Data | Cause: NV Media Card data not found. Access attempted on a non-existent file. Remedy:
| 180 Card Option | Cause: Option module installed is different between source drive and destination drive. Remedy:
| 175 Card Product | Cause: NV Media Card data blocks are not compatible with the drive derivative. Sub-trip 1: Drive Derivative (11.028) differs. Sub-trip 2: Product Type (11.063) differs or file corrupted. Remedy:
| 186 Card Rating | Cause: The voltage and/or current rating of the source and destination drives are different. Remedy:
| 181 Card Read Only | Cause: NV Media Card has the Read Only bit set. Attempt made to modify read-only data. Remedy:
| 174 Card Slot | Cause: Option module file transfer has failed. The option module does not respond correctly. Remedy:
| 35 Control Word | Cause: Trip initiated from the Control Word (06.042) when bit 12 is set and control word is enabled. Remedy:
| 225 Current Offset | Cause: Current feedback offset error. The current offset is too large to be trimmed. Remedy:
| 97 Data Changing | Cause: Drive parameters are being changed. A user action or file system write is active while the drive is enabled (e.g., loading defaults, changing mode, transferring card data). Remedy:
| 110 DCCT Ref | Cause: DCCT Reference out of range for size 5 upwards only. Remedy:
| 246 Derivative ID | Cause: Derivative file error. Sub-trip 1: File missing or invalid. Sub-trip 2: File does not match control board hardware. Sub-trip 3: File has been changed for a different derivative number. Remedy:
| 248 Derivative product image error | Cause: The Derivative Image trip indicates that an error has been detected in the derivative product image. The reason for the trip can be identified by the sub-trip number. Remedy:
| 199 Destination parameter conflict | Cause: The Destination trip indicates that destination parameters of two or more functions (Menus 7, 8, 9, 12 or 14) within the drive are writing to the same parameter. Remedy:
| 232 Drive configuration | Cause: The hardware ID does not match the user software ID. Remedy:
| 31 EEPROM Fail | Cause: Default parameters have been loaded. This indicates that default parameters have been loaded due to corrupted data (User Save or Power Down Save) or checksum failure in the non-parameter area of the EEPROM. Remedy:
| 6 External Trip | Cause: An External Trip trip has occurred. This is initiated by writing a value of 6 in Pr 10.038 or via digital input. Remedy:
| 173 Fan Fail | Cause: Fan fail. This trip cannot be reset until 10 s after the trip was initiated. Remedy:
| 247 File changed | Cause: The file system configuration or data has changed. Remedy:
| 237 FW incompatible | Cause: The FW incompatible trip indicates that the user firmware is incompatible with the power firmware. Remedy:
| HF01 Data processing error: CPU hardware fault | Cause: A CPU address error has occurred. This trip indicates that the control PCB on the drive has failed. Remedy:
| HF02 Data processing error: CPU memory management fault | Cause: A DMAC address error has occurred. This trip indicates that the control PCB on the drive has failed. Remedy:
| HF03 Data processing error: CPU has detected a bus fault | Cause: A bus fault has occurred. This trip indicates that the control PCB on the drive has failed. Remedy:
| HF04 Data processing error: CPU has detected a usage fault | Cause: A usage fault has occurred. This trip indicates that the control PCB on the drive has failed. Remedy:
| HF07 Data processing error: Watchdog failure | Cause: A watchdog failure has occurred. This trip indicates that the control PCB on the drive has failed. Remedy:
| HF08 Data processing error: CPU Interrupt crash | Cause: A CPU interrupt crash has occurred. This trip indicates that the control PCB on the drive has failed. Remedy:
| HF09 Data processing error: Free store overflow | Cause: A free store overflow has occurred. This trip indicates that the control PCB on the drive has failed. Remedy:
| HF11 Data processing error: Non-volatile memory comms error | Cause: A non-volatile memory comms error has occurred. This trip indicates that the control PCB on the drive has failed. Remedy:
| HF12 Data processing error: Main program stack overflow | Cause: The main program stack overflow has occurred. This trip indicates that the control PCB on the drive has failed. Remedy:
| HF16 Data processing error: RTOS error | Cause: A RTOS error has occurred. This trip indicates that the control PCB on the drive has failed. Remedy:
| HF18 Data processing error: Internal flash memory has failed | Cause: The internal flash memory has failed when writing option module parameter data. Remedy:
| HF19 Data processing error: CRC check on the firmware has failed | Cause: The CRC check on the drive firmware has failed. The drive is now in its Bootloader and is waiting for a new image. Remedy:
| HF23 Hardware fault | Cause: General hardware failure. Remedy:
| 250 Hot Rect/Brake | Cause: Over-temperature detected on input rectifier or braking IGBT. Remedy:
| 231 I cal. range | Cause: Current calibration range error. Remedy:
| 26 I/O Overload | Cause: The total current drawn from the AI adaptor 24 V or from the digital output has exceeded the limit. Remedy:
| 34 Keypad Mode | Cause: The drive is in keypad mode [Reference Selector (01.014) = 4 or 6] and the keypad has been removed or disconnected. Remedy:
| 90 LF Power Comms | Cause: Communication has been lost / errors detected between power, control and rectifier modules. Remedy:
| 20 Motor Too Hot | Cause: Motor thermal overload detected based on the Motor Rated Current and Thermal Time Constant. The drive trips when the estimated motor temperature reaches 100%. Remedy:
| 236 No power board | Cause: No communication between the power and control boards. Remedy:
| 219 OHt Control | Cause: Control stage over-temperature detected (often if Cooling Fan Control = 0). This causes the option module to go to standby. Remedy:
| 27 OHt dc bus | Cause: DC bus component over temperature based on a software thermal model. Causes include output current effects and DC bus ripple. Remedy:
| 21 OHt Inverter | Cause: IGBT junction over-temperature detected based on a software thermal model (Trip at 145 °C). Remedy:
| 22 OHt Power | Cause: Power stage over-temperature has been detected. The sub-trip identifies the specific thermistor location. Remedy:
| 3 OI ac | Cause: Instantaneous output over current detected (exceeded Pr 11.061). Can be caused by short circuits or incorrect loop gains. Remedy:
| 92 OI Snubber | Cause: Over-current condition detected in the rectifier snubbing circuit. Remedy:
| 4 OI Brake | Cause: Over current detected in braking IGBT or braking IGBT protection has been activated. Remedy:
| 98 Out Phase Loss | Cause: Output phase loss detected at the drive output while running. Remedy:
| 228 Output phase s/c | Cause: Over-current detected on drive output when enabled. Possible motor ground fault. Remedy:
| 7 Over Speed | Cause: Motor frequency has exceeded the over frequency threshold set in Pr 03.008 or derived from Pr 01.006. Remedy:
| 2 Over Volts | Cause: DC bus voltage has exceeded the peak level or maximum continuous level for 15 seconds. Remedy:
| 32 Phase Loss | Cause: Supply phase loss, large supply imbalance, or excessive DC bus ripple. Remedy:
| 235 Power Board HF | Cause: Power processor hardware fault. Remedy:
| 245 Power Boot Mode | Cause: Power board is in bootloader mode. Remedy:
| 93 Power Comms | Cause: Communication has been lost / errors detected between control and power board (e.g., PLL range out of lock, CRC error). Remedy:
| 220 Power Data | Cause: Power system configuration data error. This trip indicates that there is an error in the configuration data stored in the power system. The trip is related to the table uploaded from the power system at power-up. Remedy:
| 37 Power Down Save | Cause: Power down save error. The Power Down Save trip indicates that an error has been detected in the power down save parameters saved in non-volatile memory. Remedy:
| 5 PSU | Cause: Internal power supply fault. The PSU trip indicates that one or more internal power supply rails are outside limits or overloaded. Remedy:
| Reserved Various Codes | Cause: Reserved trips. Codes: 01, 09, 12, 14-17, 23, 38, 39, 91, 94-95, 99, 101-109, 111, 168-172, 176, 191-198, 205-217, 222-224, 229-230, 233, 238-244, 251-254. These trip numbers are reserved for future use and should not be used by user application programs. Remedy:
| 33 Resistance | Cause: Measured resistance has exceeded the parameter range. The measured stator resistance of the motor during an auto-tune test has exceeded the maximum possible value, or a value written exceeds the limit. This can occur if the motor is very small in comparison to the rating of the drive. Remedy:
| 204 Slot 1 Different | Cause: Option module in option slot 1 has changed. The option module in slot 1 is a different type to that installed when parameters were last saved. Remedy:
| 202 Slot 1 Error | Cause: Option module in option slot 1 has detected a fault. The option module in slot 1 has detected an error. The reason can be identified by the sub-trip number. Remedy:
| 200 Slot 1 HF | Cause: Option module 1 hardware fault. The drive detected a hardware fault with the module in Slot 1. Causes vary by sub-trip (e.g., ID failure, memory insufficient, timeout). Remedy:
| 203 Slot 1 Not Fitted | Cause: Option module in option slot 1 has been removed. The option module in slot 1 has been removed since the last power up. Remedy:
| 201 Slot 1 Watchdog | Cause: Option module watchdog function service error. The option module installed in Slot 1 started the watchdog function and failed to service it correctly. Remedy:
| 226 Soft Start | Cause: Soft start relay failed to close, soft start monitor failed. The soft start relay in the drive failed to close or the monitoring circuit has failed. Remedy:
| 234 STO Error | Cause: No Safe Torque Off board fitted. The STO board is not fitted. Remedy:
| 221 Stored HF | Cause: Hardware trip has occurred during last power down. A hardware trip (HF01 – HF18) occurred and the drive has been power cycled. Remedy:
| 227 Sub-array RAM | Cause: RAM allocation error. An option module derivative or user program image has requested more parameter RAM than is allowed. Remedy:
| 218 Temp Feedback | Cause: Internal thermistor has failed. An internal thermistor has failed in the drive (open circuit or short circuit). Remedy:
| 10 Th Brake Res | Cause: Brake resistor over temperature. Hardware based braking resistor thermal monitoring is connected and the resistor is overheating. Remedy:
| 25 Th Short Circuit | Cause: Motor thermistor short circuit. The motor thermistor connected to terminal 14 (digital input 5) is short circuit or low impedance (<50 Ω). Remedy:
| 24 Thermistor | Cause: Motor thermistor over-temperature. The motor thermistor connected to terminal 14 indicates a motor over-temperature. Remedy:
| 8 User OI ac | Cause: User OI ac trip. Initiated if the output current of the drive exceeds the trip level set by User Over Current Trip Level (Pr 04.041). Remedy:
| 96 User Prog Trip | Cause: Trip generated by an onboard user program. This trip is initiated from within an onboard user program using a function call. Remedy:
| 249 User Program (Onboard user program error) | Cause: An error has been detected in the onboard user program image. The sub-trip indicates the reason for the trip (e.g., Divide by zero, Undefined trip, Array bounds violation, CRC failure). Remedy:
| 36 User Save | Cause: User Save error / not completed. The trip indicates that an error has been detected in the user save parameters saved in non-volatile memory. For example, following a user save command, if the power to the drive was removed when the user parameters were being saved. Remedy:
| 40 – 89, 112 – 167 User Trip | Cause: User generated trip. These trips are not generated by the drive and are to be used by the user to trip the drive through an application program. Remedy:
| 30 Watchdog | Cause: Control word watchdog has timed out. The Watchdog trip indicates that the control word has been enabled and has timed out. Remedy:
| HFxx Internal faults | Cause: Internal drive problems (Trips HF01 to HF23). Remedy:
| {Stored HF} Stored HF trip | Cause: A non-permanent HF trip occurred and the drive was power cycled. The sub-trip number indicates the original HF fault code. Remedy:
| 218 to 247, {Slot 1 HF} Non-resettable trips | Cause: Severe hardware or software fault. Remedy:
| {EEPROM Fail} Volatile memory failure | Cause: Failure in volatile memory (RAM/EEPROM) consistency. Remedy:
| 174, 175, 177 to 188 NV Media Card trips | Cause: Issues related to the Non-Volatile Media Card. Remedy:
| {PSU} Internal 24V | Cause: Rectifier 24 V internal supply issue. Remedy:
| {OI.ac}, {OI Brake}, {Fan Fail} Trips with extended reset times | Cause: Over-current or Fan failure detected. Remedy:
| {Phase Loss}, {OHt dc bus} Phase loss and d.c. link protection | Cause: Input phase loss detected or DC link thermal protection active. Remedy:
| Brake Resistor Brake resistor overload | Cause: Braking Resistor Thermal Accumulator (10.039) has reached 75.0% of the trip value. Remedy:
| Motor Overload Motor Protection Accumulator Warning | Cause: Motor Protection Accumulator (4.019) has reached 75.0% of the trip value and load is >100%. Remedy:
| Drive Overload Drive over temperature | Cause: Percentage of Drive Thermal Trip Level (07.036) is greater than 90%. Remedy:
| Auto Tune Auto tune in progress | Cause: The autotune procedure has been initialized. Remedy:
| Limit Switch Limit switch active | Cause: Indicates that a limit switch is active causing the motor to be stopped. Remedy:
| Option Slot 1 Option slot alarm | Cause: Alarm generated by the module in Slot 1. Remedy:
| Low AC Low voltage mode | Cause: Drive is in Low Voltage mode. Remedy:
| Current limit Current limit active | Cause: Drive is operating at current limit. Remedy:
| 24V Backup Lost 24V Backup not present | Cause: The 24V backup supply is missing. Remedy:
| Inhibit Drive inhibited | Cause: Safe Torque Off (STO) signals not applied or Pr 06.015 is set to 0. Remedy:
| Ready Drive ready | Cause: Drive enable is active, but inverter is not active (final drive run not active). Remedy:
| Stop Drive stopped | Cause: Drive is holding zero frequency. Remedy:
| Run Drive running | Cause: Drive is active and running. Remedy:
| Supply Loss Supply loss condition | Cause: Supply loss condition has been detected. Remedy:
| Deceleration Decelerating | Cause: Motor is decelerating to zero because final drive run was deactivated. Remedy:
| dc Injection DC Injection Braking | Cause: The drive is applying DC injection braking. Remedy:
| Trip Drive Tripped | Cause: The drive has tripped and is no longer controlling the motor. Remedy:
| Under Voltage Under voltage state | Cause: Drive is in under voltage state (low or high voltage mode). Remedy:
| Heat Motor pre-heat | Cause: The motor pre-heat function is active. Remedy:
Advanced Diagnostic Tip: The M400 supports an onboard PLC (Machine Control Studio). If you encounter a User Trip, it may be triggered by custom logic within the drive’s CODESYS-based internal program.
How to Read M400 Faults via Connect Software
In 2026, the most effective way to troubleshoot the Unidrive M400 is using the Control Techniques Connect software. This tool allows for a “deep dive” into the drive’s parameters and internal logic.
- Onboard RS485 & SI-Slot: Connect via the built-in RS485 port. The M400 also features an SI-option slot for industrial Ethernet protocols (Profinet, EtherNet/IP), allowing for remote diagnostics over the plant network.
- Detailed Trip Log (Menu 10): The M400 stores the last 10 trips in Parameters 10.020 to 10.029. With “Connect,” you can view these along with “Freeze Frame” data—the exact voltage, current, and frequency at the moment of the trip.
- Sub-trip Mnemonic: Parameter 10.070 displays a sub-trip string. This is vital for hardware-related trips as it identifies which specific internal module or option slot caused the shutdown.
- PLC Diagnostics: If the M400’s internal PLC is used, “Connect” can help you identify if a User Trip was caused by a logical condition in the CODESYS environment.
Q: What is the difference between a Trip and a Warning on the M400?
A: A Trip (Solid code) is a protective shutdown that stops the motor. A Warning (Flashing code) indicates the drive is nearing a threshold—such as Hot (Heatsink temperature)—and provides an opportunity to adjust the process before a hard shutdown occurs.
Q: How do I reset a Unidrive M400 fault?
A: Once the cause is cleared, you can reset the drive by:
- Pressing the Red STOP/RESET button on the LCD keypad.
- Cycling the Main Power (Wait for the display to turn off fully).
- Toggling a Digital Input assigned to the “Reset” function (Parameter 10.033).
- Sending a reset command via Modbus RTU or an optional fieldbus module.
Q: What does “inh” (Inhibit) mean?
A: “inh” is not a fault. It is a status code indicating that the Safe Torque Off (STO) terminals (terminals 31 and 34) are not receiving a 24V signal. The drive is healthy but prevented from running by an external safety circuit.
Q: Where is the fault history stored?
A: The trip history is stored in non-volatile memory in Menu 10. Even if the drive is powered down for long-term maintenance, the last 10 trips are retained for your review.
Q: My drive shows “SlotX.Er,” what does this mean?
A: This indicates an error with an SI-Option module in the expansion slot. It could be due to a communication timeout on the fieldbus or a hardware failure within the module itself.
