ABB ACS880 Modbus Guide: Wiring, Parameters & Registers
ABB ACS880 Modbus Guide: Wiring, Parameters & Registers – In this article get complete information about ACS880 drive modbus communication include parameters, wiring, registers and step by step guide.
Part 1 : Wiring
ACS880 control units (like the ZCU-12 or ZCU-14) have an RS-485 terminal block built-in (Terminals X5). If you are using this, you don’t need the adapter, but the parameter groups change.
abb acs880 drive modbus communication  wiring
Part 2 : Parameter
Wiring is only half the battle. Now you need to tell the ACS880 how to listen. If you are using the FSCA-01 module, you are looking at Group 50, 51, 52, and 58.
ParameterSettingWhy?
50.01 FBA A EnableEnable (e.g., Option slot 1)Activates the module.
51.02 Node Address1 to 247Must match your PLC setting exactly.
51.03 Baud Ratee.g., 19.2 kbit/sSpeed of data. Must match the PLC.
51.04 Paritye.g., 8 EVEN 1Data format. 8N1 or 8E1 are standard.
51.27 FBA A RefreshRefreshCRITICAL: Changes to 51.02-51.04 won’t take effect until you cycle power OR set this parameter to Refresh.
Part 3 : Modbus Registers
Once configured, your Modbus Holding Registers (4xxxx) will line up exactly as the old drive did:
AddressContent
40001Control Word (Inputs)
40002Reference 1 (Speed)
40004Status Word (Outputs)
40005Actual Value 1 (Speed Feedback)
40006Actual Value 2 (Torque/Current)
By ensuring your termination resistor is engaged at the end of the line, you solve the physical connection issues.
