Acre to Square Chain Converter
Quickly convert acres to square chains. Learn the exact 1:10 land surveying conversion formula, history of Gunter’s chain, and view lookup tables.
Area Converter
Acre ↔ Square Chain
The Formula
Converting acres to square chains is one of the cleanest calculations in traditional land surveying because the acre was originally defined using the chain unit. Exactly 10 square chains make up one standard acre. To convert an area from acres to square chains, you multiply the number of acres by 10.
Conversion Formula:
Square Chains (sq ch) = Acres × 10
Conversely, if you need to perform the reverse calculation to convert square chains back into acres, you simply divide your value by 10 (or multiply by 0.1).
Acre to Square Chain Conversion Table
Use this reference table to check common agricultural layouts and historical property plot sizes:
Acres (ac)Square Chains (sq ch / ch²)Equivalent Square Feet
0.1 ac1 sq ch4,356 sq ft
0.25 ac (Quarter Acre)2.5 sq ch10,890 sq ft
0.5 ac (Half Acre)5 sq ch21,780 sq ft
1 ac10 sq ch43,560 sq ft
2 ac20 sq ch87,120 sq ft
5 ac50 sq ch217,800 sq ft
10 ac100 sq ch435,600 sq ft
Contextual Information & Surveying History
The relationship between an acre and a square chain is deeply rooted in the history of English and North American real estate mapping:
  • Gunter’s Chain: Invented by Edmund Gunter in 1620, a standard surveyor’s chain measures exactly 66 feet long and is divided into 100 individual iron links. A square chain represents an area measuring 1 chain by 1 chain (66 feet × 66 feet), which equals exactly 4,356 square feet.
  • The Origin of the Acre: Historically, an acre was defined as the area of a rectangular field measuring 10 chains long (one furlong) by 1 chain wide. Multiplying 10 chains by 1 chain results in exactly 10 square chains, yielding the standard 43,560 square feet we use today.
Modern Legal Applications: While everyday real estate agents list property dimensions in square feet or decimals of an acre, square chains are frequently found in historical land records, public land boundary descriptions, and rural agricultural deeds. In public land frameworks like the US Public Land Survey System (PLSS) or older Canadian boundary surveys, understanding this simple 1:10 ratio allows title searchers and surveyors to interpret legacy blueprints without rounding errors.
Other Acres Conversion
