E10018 Motor I^2.T exceeded limit (_ecMOTOR_OVERLOAD) error in ABB MicroFlex e190 servo drive
The motor overload algorithm has integrated up to 100% and has tripped the drive to protect the motor. This will happen if the RMS current for the application exceeds the MOTORRATEDCURRENT value.
Check tuning, check motion profile. If necessary select a larger motor (which may also require an alternative drive).
