F31110 (N, A) Encoder 1: Serial communications error fault in Siemens SINAMICS S120 Drive
Serial communication protocol transfer error between the encoder and evaluation module. Fault value (r0949, interpret binary) indicates specific issues like CRC error, no response, etc.
Remedies are provided for each specific fault bit (0-14), generally involving:
- Checking for EMC compliance and proper cable shielding.
- Replacing the encoder, encoder cable, or Sensor Module.
- Verifying correct encoder type and parameterization.
- Updating Sensor Module firmware.
