Farad to Nanofarad Converter
Instantly convert Farads (F) to Nanofarads (nF). This free tool includes the F to nF formula, a quick reference table, and scientific context for capacitance units.
Conversion Factor: 1 Farad = 1,000,000,000 Nanofarads
Farad to Nanofarad Conversion Formula
To convert Farads (F) to Nanofarads (nF), the capacitance value is multiplied by 1,000,000,000. The mathematical expression is as follows:
Nanofarad (nF) = Farad (F) x 1,000,000,000
Because the nano prefix signifies one-billionth of the base unit, it takes exactly one billion nanofarads to equal one Farad. This relationship is often written in scientific notation as 10 to the power of 9.
Farad to Nanofarad Conversion Table
This quick reference table helps you convert common Farad measurements into Nanofarads:
Farad (F)Nanofarad (nF)
0.000000001 F1 nF
0.0000001 F100 nF
0.000001 F (1 uF)1,000 nF
0.001 F (1 mF)1,000,000 nF
1 F1,000,000,000 nF
Scientific Background
Understanding the Farad (F)
The Farad is the standard SI unit of electrical capacitance. Named after Michael Faraday, it measures the capacity of a conductor to store an electric charge. One Farad is a massive unit; for perspective, a 1 Farad capacitor could technically power certain LED lights for quite some time. In standard PCB design, you will rarely see components rated in whole Farads unless they are supercapacitors.
Understanding the Nanofarad (nF)
The Nanofarad is a common submultiple used for capacitors that fall between the Microfarad and Picofarad ranges. The prefix nano stands for one-billionth (10 to the power of -9). Therefore, a Nanofarad is 0.000000001 Farads. You will find nanofarad-rated capacitors in audio filters, high-frequency circuits, and decoupling applications.
Practical Application
When working with digital circuit simulations or advanced physics formulas, capacitance is almost always required in the base SI unit (Farads). However, the physical parts you buy from a supplier are almost always labeled in Microfarads or Nanofarads. This converter allows you to translate those values accurately by shifting the decimal point nine places to the right.
