flow rate unit – Definition & Universal Flow Rate Converter. Instantly convert between Liters per Minute (LPM), Gallons per Minute (GPM), Cubic Meters per Hour (m3/h), and CFM.
In the world of engineering and fluid dynamics, asking “What is the flow rate?” is rarely enough. The follow-up question is always: “Which unit are we using?”
From the water coming out of your tap to the fuel entering a jet engine, flow rate units vary wildly depending on the industry, the region, and the state of matter (liquid vs. gas). In this guide, we break down the most common flow rate units and when to use them.
Flow Rate Unit Converter
Understanding Flow Rate Units
What is Volumetric Flow Rate?
Volumetric Flow Rate (often symbolized as Q) measures the volume of fluid that passes through a given surface per unit of time. It is widely used in engineering to quantify how much water a pump moves, how much air a fan blows, or how much fuel flows through a pipe.
The basic formula is:
Q = V / t
Where Q is Flow Rate, V is Volume, and t is Time.
Common Unit Categories
Different industries use different standards. Here is a breakdown:
1. Metric System (SI & Derived)
- m³/h (Cubic Meters per Hour): The standard for industrial pumps, water treatment, and large HVAC systems.
- LPM (Liters per Minute): Common for smaller pumps, hydraulics, and medical oxygen flow.
- L/s (Liters per Second): Used in scientific calculations and instant drainage flow.
2. Imperial / US System
- GPM (Gallons per Minute): The standard for plumbing, irrigation, and firefighting in the USA (US GPM) and UK (Imperial GPM). Note: 1 US Gallon ≠ 1 UK Gallon.
- CFM (Cubic Feet per Minute): The standard for air compressors, fans, and ventilation (HVAC) in North America.
Quick Conversion Table
Reference chart for converting 10 m³/h into other units:
| Unit | Equivalent to 10 m³/h | Typical Use |
| Liters/min (LPM) | 166.7 | General Industry |
| US Gallons/min (GPM) | 44.03 | Water Pumps (USA) |
| UK Gallons/min (GPM) | 36.66 | Water Pumps (UK) |
| Cubic Feet/min (CFM) | 5.89 | Air Flow |
| Liters/sec (L/s) | 2.78 | Science / Lab |
