How can resolve problem CE10 Modbus transmission time-out fault in delta ME300 series drive ?
Cause : Modbus transmission time-out occurs.
When the communication time exceeds the detection time for Pr.09-03 time-out.
Verify the wiring and grounding of the communication circuit. It is recommended
to separate the communication circuit from the main circuit, or wire in 90 degree
for effective anti-interference performance.
Check the cable and replace it if necessary.
Fault treatment parameter
Pr.09-02
0: Warn and continue operation
1: Fault and ramp to stop
2: Fault and coast to stop
3: No warning, no fault and continue operation
