scf3 fault in schneider drive
[#20720]
SCF3 fault in Schneider drive (ATV320, ATV61, ATV71, etc.) indicates a Ground Short Circuit fault detected at start-up or during operation. This means the drive has detected a short circuit to ground in the motor or its wiring.
Common Causes
  • Insulation Failure: Poor insulation in the motor windings or the power cables connecting the drive to the motor.
  • Long Motor Cables: High capacitance in long cables can cause significant leakage current.
  • Unbalanced Mains: Input voltage unbalance exceeding can sometimes trigger this detection in specific models.
  • Hardware Issues: Faulty IGBTs or internal drive components.
Key Troubleshooting Steps
    • Check Motor & Cables: Disconnect the motor leads and run the drive empty. If the fault disappears, the issue is in the motor or cable insulation.
    • Verify Grounding: Ensure the motor and drive are properly grounded and that there is no electrical leakage to ground.
    • Reduce Switching Frequency: Lower the switching frequency to reduce stress on insulation.
    • Check Motor Parameters:
      Ensure all motor data (voltage, current, speed) is correctly entered, and run an autotuning.
    • Check Voltage: Verify that the supply voltage is not significantly unbalanced.
