Instantly convert density from Kilogram per cubic meter ( kg/m3 ) to Gram per cubic meter (g/m3). Includes the conversion formula, a quick reference table, and physics context.
kg/m³ to g/m³ Converter
Conversion: 1 kg/m³ = 1,000 g/m³
Kilogram/cubic meter to Gram/cubic meter Formula
To convert density from Kilogram per cubic meter (kg/m³) to Gram per cubic meter (g/m³), the value is multiplied by 1,000. The mathematical formula is expressed as follows:
Value in g/m³ = Value in kg/m³ x 1,000
This conversion is based on the metric mass relationship where 1 kilogram (kg) equals 1,000 grams (g). Because the volume unit (cubic meter) remains the same in both measurements, the change applies only to the mass prefix.
Conversion Table (Quick Reference)
The following table shows common density conversions from the standard SI unit (kg/m³) to Gram per cubic meter (g/m³):
| Kilogram/cubic meter (kg/m³) | Gram/cubic meter (g/m³) |
| 0.001 kg/m³ | 1 g/m³ |
| 0.01 kg/m³ | 10 g/m³ |
| 0.1 kg/m³ | 100 g/m³ |
| 1 kg/m³ | 1,000 g/m³ |
| 1.225 kg/m³ (Sea Level Air) | 1,225 g/m³ |
| 10 kg/m³ | 10,000 g/m³ |
Scientific and Contextual Information
Understanding kg/m³ vs g/m³
The Kilogram per cubic meter (kg/m³) is the official SI unit for density. It is the primary unit used in aerospace engineering, industrial fluid systems, and structural physics. The Gram per cubic meter (g/m³) is a metric submultiple often preferred when dealing with very low concentrations of matter.
Practical Application: Atmospheric Science
In environmental science, air density is a critical variable. While engineering textbooks list the density of air as roughly 1.2 kg/m³, laboratory analysis of pollutants, dust, or humidity often expresses results in grams per cubic meter to provide higher numerical resolution without resorting to many decimal places.
Why Use this Converter?
Maintaining precision in technical data is essential for safety and accuracy. While shifting the decimal point three places to the right is mathematically simple, automated tools prevent human error during repetitive data entry. This converter ensures that your density values are correctly scaled for use in specialized laboratory reports or broad engineering simulations.
