Volts to Amps Converter
Easily convert Volts to Amps with our free online calculator. Learn the Ohm’s Law formulas to find current using resistance or power, and view our voltage-to-current reference tables.
Enter values and click Calculate
How to Convert Volts to Amps
To calculate Amps (Current), you cannot simply look at Voltage alone. Current is the result of electrical pressure (Volts) pushing against a load. To find the amperage, you must know either the Resistance of the circuit (measured in Ohms) or the Power consumption (measured in Watts).
The Formulas
Depending on your known variables, use one of the following two standard electrical formulas:
1. Using Ohm’s Law (Resistance):
Amps (I) = Volts (V) ÷ Ohms (Ω)
2. Using the Power Law (Watts):
Amps (I) = Watts (W) ÷ Volts (V)
Volts to Amps Reference Table
This table illustrates the Amperage for standard voltages when used with a fixed 1000-Watt appliance or a 20-Ohm load.
Voltage (Volts)Current at 1000WCurrent at 20 Ω
12 Volts83.33 Amps0.60 Amps
24 Volts41.67 Amps1.20 Amps
120 Volts8.33 Amps6.00 Amps
240 Volts4.17 Amps12.00 Amps
Key Concepts & Analogies
The Water Analogy:
To understand electricity, imagine water flowing through a pipe.
  • Volts are the water pressure.
  • Amps are the volume of water flowing through the pipe.
  • Ohms (Resistance) is the size of the pipe. If the pipe is narrow (high resistance), less water (Amps) flows even if the pressure (Volts) is high.
Why does Amperage matter?
Amperage determines the thickness of the wire needed for a circuit. High amperage generates heat; if a wire is too thin for the Amps running through it, the wire can melt or cause a fire. This is why high-voltage power lines (low Amps) can carry massive amounts of power over long distances using relatively thin cables.
Common Conversion Scenarios
  • Solar Panels: If a 200W solar panel is producing 20V, it is providing 10 Amps to your charge controller.
  • Home Appliances: A 1500-Watt heater plugged into a 120V outlet draws 12.5 Amps.
  • Automotive: A 12V headlight with a resistance of 3 Ohms draws 4 Amps of current.
Notice: Always ensure your circuit breakers and wiring are rated for the Amperage your devices will draw. Consult an electrician for complex installations.
