AL. 032.1 Overcurrent detected via hardware (during operation) fault in Mitsubishi MELSERVO MR-JET Servo Drive
Cause: Servo motor power cable has a ground fault or short.
  • Check cable for shorts/ground faults. Replace if necessary.
  • Disconnect cable and check if alarm persists (implies Amplifier fault).
Cause: Servo motor has malfunctioned (Ground fault/Short).
  • Check insulation between phases (U/V/W) and ground. Replace motor if failed.
Cause: Dynamic brake malfunction or Regenerative resistor wiring error.
  • Check wiring of regenerative options.
  • Replace servo amplifier if internal brake failed.
Cause: Noise/Environment.
  • Implement noise reduction techniques.
