Celsius to Fahrenheit (°C to °F) Converter
Convert Celsius to Fahrenheit instantly with our free online calculator. Includes the °C to °F formula, a quick reference temperature table, and common temperature milestones.
Temperature Converter
How to Convert Celsius to Fahrenheit
Converting Celsius (°C) to Fahrenheit (°F) is a standard temperature conversion used globally. While the metric-based Celsius scale is used by almost every country for daily weather and scientific research, the United States still primarily uses the Fahrenheit scale.
The Conversion Formula
To find the temperature in Fahrenheit, multiply the Celsius value by 9/5 (or 1.8) and then add 32. The exact mathematical formula is:
°F = (°C × 9/5) + 32
Celsius to Fahrenheit Quick Reference Table
Use this reference table for common temperature benchmarks used in travel, science, and health:
Celsius (°C)Fahrenheit (°F)Milestone
-40°C-40°FThe point where both scales meet
0°C32°FFreezing point of water
20°C68°FComfortable room temperature
30°C86°FA hot summer day
37°C98.6°FAverage human body temperature
100°C212°FBoiling point of water
Context: Why Use Our Converter?
Temperature affects almost every aspect of our lives, from cooking and health to global logistics. While a quick mental shortcut is to double the Celsius and add 30, this becomes increasingly inaccurate as temperatures rise or fall. For instance, using the shortcut on 100°C would give you 230°F, which is 18 degrees off from the real boiling point!
  • International Travel: If you are visiting the US from a metric country (or vice versa), knowing if 25°C is “beach weather” or “coat weather” is vital.
  • Science & Industry: Laboratory settings often require high-precision temperature data for chemical reactions.
  • Culinary Arts: Many professional baking recipes from Europe use Celsius, while US ovens are calibrated in Fahrenheit.
Our tool uses the precise mathematical ratio of 1.8 to ensure your results are accurate to the decimal point, whether you’re adjusting a thermostat or performing a scientific experiment.
