Coulomb to Microcoulomb (C to μC) Converter
Instantly convert Coulombs (C) to Microcoulombs (μC). Includes the conversion formula, a quick reference table, and detailed electrical charge definitions.
Coulomb to Microcoulomb Converter
Coulomb to Microcoulomb Formula
To convert electric charge from Coulombs (C) to Microcoulombs (μC), you multiply the charge by one million. The Microcoulomb is a submultiple of the Coulomb, which is the base unit of electric charge in the SI system.
1 Coulomb (C) = 1,000,000 Microcoulombs (μC)
Formula: μC = C × 106
Conversion Quick Reference Table
Use this table to find the most common conversions from Coulombs to Microcoulombs.
Coulombs (C)Microcoulombs (μC)
0.000001 C1 μC
0.0001 C100 μC
0.001 C1,000 μC
0.01 C10,000 μC
0.1 C100,000 μC
1 C1,000,000 μC
Understanding Electric Charge Units
What is a Coulomb?
The Coulomb (C) is the International System of Units (SI) unit of electric charge. It is defined as the quantity of electricity transported in one second by a current of one ampere. One Coulomb is equivalent to the charge of approximately 6.242 × 1018 electrons.
What is a Microcoulomb?
A Microcoulomb (μC) is a decimal submultiple of the Coulomb. Because a full Coulomb is a very large amount of charge for electronic components, Microcoulombs are much more frequently used when discussing the charge stored in capacitors or the static electricity found in daily life.
Real-World Examples
  • Static Electricity: A typical spark of static electricity generated by walking across a carpet and touching a doorknob involves a charge in the range of 1 to 10 μC.
  • Capacitors: A common 10μF (microfarad) capacitor charged to 10 Volts stores exactly 100 μC of charge.
  • Lightning Bolts: A single lightning strike can transfer anywhere from 1 to 20 Coulombs of charge, which is 1,000,000 to 20,000,000 μC.
