Convert energy units instantly. Switch between Joules (J), Calories (cal), Kilowatt-hours (kWh), British Thermal Units (BTU), and Foot-pounds. Free tool with formulas and tables.
Energy Converter
How to Convert Energy Units
Energy is defined in physics as the capacity for doing work. It exists in many forms, including kinetic, potential, thermal, and electrical. Because different industries use different measurement systems, converting between units like Joules, Calories, and BTUs is a common necessity.
Common Energy Conversion Formulas
To convert energy manually, you can use the following standard conversion factors based on the Joule (the SI unit of energy):
- Calories to Joules: J = cal × 4.184
- Kilowatt-hours to Joules: J = kWh × 3,600,000
- BTU to Joules: J = BTU × 1,055.06
- Kilojoules to Kilocalories: kcal = kJ ÷ 4.184
Energy Quick Reference Table
Use this table to find equivalent values for common energy benchmarks:
| Unit | Joules (J) | Kilocalories (kcal) |
| 1 Joule (J) | 1 J | 0.000239 kcal |
| 1 Kilojoule (kJ) | 1,000 J | 0.239 kcal |
| 1 Kilocalorie (Food Cal) | 4,184 J | 1 kcal |
| 1 BTU | 1,055 J | 0.252 kcal |
| 1 Kilowatt-hour (kWh) | 3,600,000 J | 860.4 kcal |
Context: Why These Units Matter
- Physics (Joule): The SI unit, equal to the work done by a force of one newton moving an object one meter.
- Nutrition (kcal): Often called “Calories” on food labels, these measure the energy potential in food. Note that 1 kcal = 1,000 “small” calories.
- Electricity (kWh): Used by utility companies to measure home energy consumption. 1 kWh is the energy used by a 1,000-watt appliance running for one hour.
- Heating (BTU): The British Thermal Unit is used primarily in the US for rating air conditioners and heaters. It is the energy needed to heat one pound of water by 1°F.
Why Use This Converter?
Converting between work (Joules), heat (BTUs), and nutritional energy (kcal) involves large multipliers that are easy to miscalculate. This tool ensures accuracy for students, engineers, and fitness enthusiasts alike, providing instant results across all major energy scales.
