Frequency Conversion Calculator
Convert frequency units instantly. Switch between Hertz (Hz), Kilohertz (kHz), Megahertz (MHz), Gigahertz (GHz), and RPM. Includes frequency formulas and conversion tables.
Frequency Converter
Understanding Frequency Units
Frequency is the number of occurrences of a repeating event per unit of time. In the International System of Units (SI), the unit of frequency is the Hertz (Hz), which equals one cycle per second.
The Frequency Conversion Formula
Frequency units are based on a metric scale (powers of 1,000). To convert between them, you can use these simple factors:
  • Kilohertz (kHz): Hz ÷ 1,000
  • Megahertz (MHz): kHz ÷ 1,000
  • Gigahertz (GHz): MHz ÷ 1,000
  • RPM to Hz: RPM ÷ 60
Frequency Quick Reference Table
Common benchmarks for frequency measurements across different technologies:
UnitHertz (Hz)Common Use Case
1 kHz1,000 HzAudio Frequencies
1 MHz1,000,000 HzAM/FM Radio Waves
1 GHz1,000,000,000 HzCPU Speeds / Wi-Fi
60 RPM1 HzEngine Rotation
Context: Where is Frequency Used?
  • Computing: Clock speed (measured in GHz) determines how many instructions a processor can execute per second.
  • Music: Pitch is determined by frequency. For example, "Concert A" is standardized at 440 Hz.
  • Telecommunications: Different bands (MHz for LTE, GHz for 5G) allow for data transmission through the atmosphere.
  • Mechanical Engineering: RPM (Revolutions Per Minute) is used to measure the speed of motors and fans, which can be converted to Hz to analyze vibration.
Why Use This Converter?
Whether you are calculating the wavelength of a radio signal, tuning a musical instrument, or checking a processor's performance, switching between Hz, MHz, and GHz is a daily task. This tool provides a fast, accurate way to handle these large-scale numbers without manual calculation errors.
