Joules to Watts Converter
Convert Joules (J) to Watts (W) instantly with our free online calculator. Learn the energy-to-power formula (P = E/t), see reference tables, and understand the relationship between Joules and Watts.
Enter energy and time to calculate power
How to Convert Joules to Watts
To convert Joules (J) to Watts (W), you must divide the total energy by the amount of time in seconds over which that energy is used. While Joules measure the total quantity of energy, Watts measure the rate at which that energy is being consumed or produced.
The Formula
The relationship between energy, power, and time is defined by the following equation:
Watts (W) = Joules (J) ÷ Time (s)
One Watt is equivalent to one Joule of energy per second.
Joules to Watts Quick Reference Table
This table illustrates the resulting power (Watts) for common energy amounts (Joules) over different time intervals.
Energy (Joules)Time (Seconds)Resulting Watts
100 J1 second100 W
1,000 J10 seconds100 W
3,600 J60 seconds (1 min)60 W
60,000 J60 seconds (1 min)1,000 W (1 kW)
Contextual Information
Joules (Energy) vs. Watts (Power)
The difference between Joules and Watts is often compared to a water tank. Joules are the total amount of water in the tank (potential energy). Watts are the rate at which the water flows out of the tap (power). A small tap running for a long time can expend the same amount of Joules as a large tap running for a very short time.
Real-World Applications
  • Lighting: A 60-Watt light bulb consumes 60 Joules of energy every single second it is turned on.
  • Heating: A 1,500-Watt space heater uses 1,500 Joules of energy per second. If it runs for one hour (3,600 seconds), it consumes 5.4 million Joules.
  • Nutrition: Food energy is often measured in Calories, but it can also be measured in Joules. One dietary Calorie (kcal) is approximately 4,184 Joules.
Why use this converter?
Calculating the Joules to Watts ratio is critical in engineering and physics to determine the efficiency of machines and electrical components. By understanding how much power is required to expend a specific amount of energy in a set timeframe, you can better manage power supplies, battery life, and thermal management in electronic devices.
