KB to GB Converter
Quickly convert Kilobytes (KB) to Gigabytes (GB) with our free online calculator. Includes the exact conversion formula, a quick reference table, and technical storage facts.
Storage Converter
How to Convert KB to GB
Converting Kilobytes (KB) to Gigabytes (GB) is a necessary step when analyzing large datasets, server logs, or cloud storage limits. Because computer systems operate on binary logic, the jump from KB to GB involves two steps of 1,024.
The Conversion Formula
In standard binary computing (Base 2), there are 1,024 Kilobytes in a Megabyte and 1,024 Megabytes in a Gigabyte. Therefore, one Gigabyte contains 1,048,576 Kilobytes. To convert KB to GB, you divide the number of Kilobytes by 1,048,576. The mathematical formula is:
GB = KB ÷ 1,048,576
KB to GB Quick Reference Table (Binary Standard)
Use this reference table for common data sizes using the 1,024 binary standard:
Kilobytes (KB)Gigabytes (GB)
1,024 KB0.000977 GB (1 MB)
100,000 KB0.095367 GB
524,288 KB0.5 GB
1,048,576 KB1.0 GB
2,097,152 KB2.0 GB
10,000,000 KB9.536743 GB
Context: Why the Big Number?
You may sometimes see people divide by 1,000,000 (the decimal standard). However, technical environments use the binary standard because it aligns with how RAM and CPU registers manage data:
  • Software Developers: Use the binary standard (1024) to ensure application memory allocation is exact.
  • Cloud Providers: AWS, Google Cloud, and Azure often bill based on binary units (GiB), though they may label them simply as GB.
  • Hard Drive Brands: Use the decimal standard (1,000) to make their drives look larger. This is why a “1,000,000 KB” file is less than 1 GB in Windows.
Why Use Our Converter?
Manually dividing by a seven-digit number like 1,048,576 is nearly impossible to do accurately without a calculator. Our tool provides high-precision results instantly, ensuring your technical specifications, data audits, or file transfers are calculated with 100% accuracy.
