Quickly convert Kiloamperes (kA) to Amperes (A) with our free online tool. Learn the kA to A conversion formula, view our quick reference table, and understand high-current applications.
kA to Ampere Converter
The Kiloampere to Ampere Formula
To convert electric current from Kiloamperes (kA) to Amperes (A), you multiply the value by 1,000. In the metric system, the prefix “kilo” stands for a factor of one thousand (103).
Amperes (A) = Kiloamperes (kA) × 1,000
Kiloampere to Ampere Conversion Table
This quick reference chart helps you instantly find common conversions for high-power electrical systems:
| Kiloamperes (kA) | Amperes (A) |
| 0.1 kA | 100 A |
| 0.5 kA | 500 A |
| 1 kA | 1,000 A |
| 2.5 kA | 2,500 A |
| 5 kA | 5,000 A |
| 10 kA | 10,000 A |
| 50 kA | 50,000 A |
Contextual Information
What is a Kiloampere (kA)?
A Kiloampere (kA) is a unit of electric current equal to 1,000 Amperes. It is used in situations involving very high power, such as industrial metal smelting, electrical power grids, and lightning research. For example, a typical residential circuit breaker might trip at 20 Amps, whereas a main power station breaker might handle several Kiloamperes.
What is an Ampere (A)?
The Ampere (A) is the SI base unit of electric current. It represents the flow of electric charge at the rate of one Coulomb per second. It is the fundamental unit from which smaller units like Milliamps (mA) and larger units like Kiloamperes (kA) are derived.
Why is this Conversion Important?
In electrical engineering, especially when dealing with commercial buildings or industrial plants, equipment specifications often alternate between Amps and kA. Understanding that 1 kA is exactly 1,000 Amps is vital for choosing the correct gauge of wire, sizing transformers, and ensuring safety through proper circuit protection.
